跳转到主内容
Help I want to fix my poor system
I have a mid 2011 11” MacBook Air. It’s the first computer I ever purchased and I learned to code on it.
It has sentimental value to me. However, it is really slow and getting practically unuseable. I have a ThinkPad that I use now for coding and work but I leave my MacBook Air on my nightstand and use it at night for entertainment.
It came with i5 and 2GB of RAM. I see on eBay that I can buy a motherboard for an 11” mid 2011 MacBook Air with an i7 and 4GB of RAM.
If I were to purchase this and swap it with my current motherboard I would be not only be doubling my memory but also upgrading my CPU. I also see that OWC sells SSD’s for this system. I would also ugrade my SSD increasing the size by 4 times and the read/writes speeds by ~2.5 times.
Should speed things up drastically and the parts will cost less than 300 bucks… Becuase of the sentimental value of this laptop, that price is well worth it to me!
Is this not an option? Am I missing something? Is there something about the two motherboards that makes them not interchangeable?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Just understand 4GB is still on the lean side for many of the heaver apps.
You have a workable idea here!
  • Replacing the logic board to a 1.8GHz i7 with 4GB of RAM (Apple P/N 661-6102)
  • Replacing the SSD with an OWC SSD. I would recommend getting as large as you can that way you have space for the system to leverage the SSD for Virtual RAM.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zack Alger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 34
