跳转到主内容
The March 2019 refresh of Apple's iPad Mini tablet, featuring an A12 Bionic SoC and an updated True Tone Retina display with Pencil support. Available in Wi-Fi and LTE with 64 and 256 GB storage options.
Delay in start charging ipad
Recently I bought an iPad mini 5, it works perfectly fine and keep battery very well but when I want to charge it when I plug it into the charger it sometimes take a few seconds (like 4-8 seconds) to start charging and I have to mention that I use Ipad’s original charger and cable and I also used anker power bank also my iPhone charge but I still have this problem.
Any one has experienced it? and anyone knows is it serious problem and is it may damage my iPad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
7个答案
最有帮助的答案
Exact same issue here on the iPad Pro 2020: can vary between 10 seconds to over a minute! And that’s with the official USB-C charging cable and fast-charge plug that came with the device
Curiously, using an old iPhone adaptor and USB to USB-C starts charging the same device immediately
And likewise: the official cable and charger are recognised immediately if the unit is powered off
Bizarre, very basic, issue
这个答案有帮助吗?
得分 1
添加一条评论
I also have this problem, I think it’s an issue in iOS/PadOS as I’ve seen iPhones also do this is some versions of iOS.
这个答案有帮助吗?
得分 0
添加一条评论
I am currently going through this issue. I have tested on Apple branded and other brands of charging wires and ports but issue remains. I’ve contacted Apple and I got my replacement today. Issue is also on the replacement.
这个答案有帮助吗?
得分 0
1条评论:
Maybe its an issue with many ipad minis, mine does the same
完成的
添加一条评论
My new ipad mini is always have this same issue :( whats wrong :( do you think this is an ios problem?
这个答案有帮助吗?
得分 0
添加一条评论
My Ipad mini 5 also has the same problem. Everything is perfectly fine but still it is anoying
这个答案有帮助吗?
得分 0
添加一条评论
Mine also does the same sometimes it takes 15 seconds, no delays when it’s powered off though
这个答案有帮助吗?
得分 0
添加一条评论
You should turn off your device before start charging..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
navid arbab 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,365
