跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
iPhone XR Battery Service warning with original battery.
I recently swapped my xr battery with another genuine battery, got the service warning, ok, so I put back the original battery, reboot, factory restore, hard reset and the warning will not go away! Any ideas? ios 13.3.1
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I checked, says battery may have been changed. But its the original battery.
完成的
Maybe a component near the battery connector got knocked off?
完成的
添加一条评论
1个答案
已选择的解决方案
That’s strange. I would check the battery info on 3uTools under verification to see if the original battery is indeed being detected.
Let us know what is displayed.
这个答案有帮助吗?
得分 1
1条评论:
I checked with 3utools, it says the battery may have been changed. It isn't even sure. While I am 100% sure. I guess because I plugged in another battery it tripped this warning and putting back the original battery does not reset the warning. Damned iOS 13!!!
完成的
添加一条评论
添加你的答案
Jimmy James 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 5
总计 336
