跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
After tightening down screen, orange stress marks above home button
When my phone screen isn’t pressed into place and screwed down, it’s fine. But as soon as I press it in and screw it in at the two bottom screws, almost straight away an orange stress mark appears at the bottom, in the same place every time. I’ve tried removing every single piece of adhesive on the screen. Could it be because I’m not using my screen adhesive to put the screen back in place, and I’m only just pressing it in without the glue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @charliewhile
How does your battery look? iPhone batteries can fail in a way that causes them to swell, sometimes only on the bottom part. As a general rule, if you see these “orange” stress marks on the LCD, there is something pushing the screen back off the frame from the inside. Check the frame directly below the stress marks for anything that might be in the way and remove it.
这个答案有帮助吗?
得分 1
2条评论:
I figured it out, I had just changed the battery and the adhesive tabs were sticking up just a little bit, that fixed it
完成的
Nice! Glad it was an easy fix
完成的
添加一条评论
添加你的答案
Charlie While 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 354
