跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
2014 iMac Dead/Stuck Pixels After SSD Upgrade
Hello!
I recently removed the screen of my 27” iMac to replace a dead HDD with a new SSD. After the repair, there are pixels that are “stuck” along the left and right edges. They do not appear when the display is a bright color, but they are very visible when the display is black. I am wondering if this is likely LCD panel damage, or perhaps a cable isn’t seated all the way?
Just curious of thoughts on this issue.
First image is on light background, second is on black.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Posting some pics would be helpful 在已经存在的问题里加入图片
完成的
@danj images added, thank you -- did not realize I had that option! :)
完成的
These look like pry marks. Besides using the cutter what did you use?
完成的
It's not pry marks, I didn't pry the display at all. I used suction cups (not in the area that is showing this issue). I gently used the wheel tool to remove the adhesive, and I did not force the display open.
完成的
添加一条评论
1个答案
最有帮助的答案
Did you follow our guide? iMac 英特尔 27 英寸 Retina 5K 显示屏更换 Did you use the special pizza cutter? iMac Opening Wheel
Often the display gets damaged by using the wrong tools and/or stressing the display when taking it off.
Update (01/24/2020)
What I suspect happened is you pressed up with a object which had a slight bump during the prying action this bump pressed along the back of the screen causing the liquid crystal to be squeezed out at this location of the pressure. Thats why you have a white make as the backlight is not being blocked by the polarization of the liquid crystal material. Most of the time I see more of a line of a screwdriver blade or spatula press than a dot as you have. Being small it’s possible they will fade over time as the liquid will ooze back as long as the back plate is not bent. Otherwise you’ll need a new display.
Cutting wheel for releasing the adhesive on some iMac models.图片
产品
iMac Opening Wheel
$7.99
这个答案有帮助吗?
得分 1
1条评论:
I did use the correct tools. I did not notice any event that would make me even remotely believe any actual damage occurred.
完成的
添加一条评论
添加你的答案
David Chaboudy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 231
