跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
After battery replacement, home button will not function!?
I recently did a battery replacement on my 6s with a ifixit kit, at first everything seemed fine upon reassembly and power on, but then I realised that my home button gave me no response, and upon startup/power on iphone came up with warning message saying “touch id not available”. Is someone able to help me with this? I did not mess with the area around the home button so not sure how this could have happened. Any help appreciated! Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First check to make sure the cables are connected all the way, Next I would check each cable for the slightest bent connector or tear in the cable. May have to use a magnifing lens, even a slight wrinkle in the cable can cause damage.
If you used any heat to separate the screen you may could have damaged the chip connected to the home button.
这个答案有帮助吗?
得分 0
3条评论:
Hi, is possible i may have slightly bent connector, but not ripped, is it possible to replace this part yourself?
完成的
If the connector on the logic board has a bent connector then you can replace it if you can micro solder, if you are not able to then you will have to send it out to have it done. If its a bent connector on the flex cable then yes you can replace it yourself.
完成的
Yeah, if the connectors are bent on the logic board or the home button cable then you might have to send it out. If one of the screen connectors is bent, you probably will need a new screen.
完成的
添加一条评论
添加你的答案
Brayden courtney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 50
