跳转到主内容
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
89 个问题 查看全部
Help!Xbox 360 E won’t stay turned on.
After a possible overheat I took apart and cleaned it. I let it set overnight and the next day it booted up just fine and I used it for about 7 hours and then I shut off and won’t stay turned on. None of the lights indicate that it to hot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Apart of the motherboard maybe fried - the xbox 360 E goes for so cheap it maybe better to replace it.
Did you clean the fan? It is working?
这个答案有帮助吗?
得分 0
1条评论:
Yes I cleaned the fan and it is working
完成的
添加一条评论
添加你的答案
Crazycakes125 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 6
总计 62
