跳转到主内容
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
How to setup the ps3 without the original controller
I bought a ps3
and he came without any accessory and i have a Genesis controller and i cant do the setup with this controller but on the box says compatible with ps3.
I need a original controller or what?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Power A controllers can easily accept different drivers for different systems. Download the controller driver from your game consoles website, to your computer. Connect your Power A controller to your PC via USB. On Windows go to control panel, devices and printers. Click on Power A. And install driver…. Done.
Enjoy.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If your controller came with a USB cable, connect it and press the PS button. If it did not, you will have to buy one. If you already have a USB cable and it still does not work, you may have to buy a controller made by Sony.
这个答案有帮助吗?
得分 1
5条评论:
You're welcome, if this helped.
完成的
Thank You so i need to buy a new controller??
完成的
If your controller does not register even with a USB cable that connects on both ends correctly, then you may have to buy a PS3 controller from somewhere, as I do not know how to get it to work otherwise. If someone else has another answer, theirs may be better. Then again, I'm not quite an adult yet, either.
完成的
Ok Thank You Very Much!!
完成的
I worked for SEA tech support, basicly helped customers remotely repair there systems over the phone...there is no way to use the safemode or restart boot menu without the official duleshock 3..no aftermarket controllers will work unless your at the homescreen and even some games have issues with the aftermarket
完成的
添加一条评论
What if I don't have original controller I have a (power a remote ) but it says connect controller to USB and press is button what I do?
这个答案有帮助吗?
得分 0
1条评论:
It says connect controller with cable. I bought this with cordless how do I reset to play?
完成的
添加一条评论
I have team5 usb controler, and my sony does not recognize it? What shoud i do?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NT GAMER1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 66
总计 14,944
