跳转到主内容
HP computer flashes red light and beeps 5 times
My HP computer flashes red light and beeps 5 times stops then 5 more on and on ,this at start up will not start . I have unplugged hard drive, memory stick replaced CMOS battery,still not starting. I have a new hard drive and CD Drive, but they are not installed for the current problem. Any ideas . Computer is HP elite Desk.
Thanks,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Hi,
What is the full model number of the desktop?
Have you re inserted the RAM module (memory stick), you didn't say?
Having no RAM module inserted will give a 5 power light blink, 5 beep error code
If you have re-inserted the module and are still getting the error light/beeps, replace the module with a compatible replacement module and check if this resolves the problem.
If it still fails it may be a memory controller issue on the motherboard
这个答案有帮助吗?
得分 3
2条评论:
If it's a memory controller issue, how can it be fixed?
完成的
@Lala Hetman
As a DIY repair you will have to replace the motherboard.
Alternatively you will need to find the motherboard schematics to find out why the memory controller isn't working
完成的
添加一条评论
The possible reason as an overloaded power supply.    Disconnect all external devices to see if any of those items are causing the problem, (such as a hard, diskette, or optical drives, and expansion cards).  Power on the system. If the system enters the POST, then power off and replace one device at a time and repeat this procedure until failure occurs. Replace the device that is causing the failure. Continue adding devices one at a time to ensure all devices are functioning properly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jeff Brewer 将永远感激不已
浏览统计数据:
过去 24 小时: 29
过去 7 天: 220
过去 30 天: 929
总计 29,466
