跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
124 个问题 查看全部
Torn ribbon ground replacing screen. See picture..
Is there a way to repair the ribbon after it has been torn? It is the two outer ribbons that seem to be grounded to the chassis.
Can this be repaired or do I need a new ribbon assembly?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
I actually put it back together as is and it’s working fine. I have no idea what they are for but they’re not affecting functionality as yet.
这个答案有帮助吗?
得分 0
1条评论:
Is your watch still working ok. I just tore the same cables?
Thanks
完成的
添加一条评论
Yes it can be repaired with the right tools and experience. Short answer, no don’t waste your time. Time is money and that part is 50x cheaper to just replace instead of spending hours to fix.
这个答案有帮助吗?
得分 0
2条评论:
完成的
I have been searching for a source for a replacement "ribbon ground", but can't find any :-o
Does any of you know of a good source and a link to it?
Thanks!
完成的
添加一条评论
Will it make a ometv chatroulette  chat avenue   difference if I use the original cable? Thanks
这个答案有帮助吗?
得分 -1
添加一条评论
++https://ometv.vip/++
++https://bazoocam.live/++
++https://omegle.monster/++
++https://chatzy.xyz/++
++https://ometv.icu/++
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
canicoll 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 25
总计 831
