跳转到主内容
加入维修社区 - 创建账户
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
No Display, Black Screen
I dropped my phone on the keyboard of my laptop and the screen went black.
My laptop failed the built in LCD screen test. I did the FN test and I gotten 3 beeps. I looked at the wires after opening the laptop up but I don't know how to check behind the LCD screen itself.
The external monitor works and I did a system diagnostic test but it said 0 issues found. Any ideas what I could do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @bto32
Here are two links that show how to remove the display assembly from the laptop so that access to the rear of the display panel is possible.
Dell 9350 service manual. Scroll to p.55 to view the necessary pre-requisite steps and then the procedure to remove / replace the display assembly.
ifixit Dell XPS 13 Display Assembly Replacement guide.
Once you have access to the rear of the display panel, you can inspect it for any obvious damage. If nothing is obvious since it has failed the diagnostic test then most probably it has suffered internal damage and needs to be replaced as it cannot be repaired.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bill T 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 788
