跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
706 个问题 查看全部
Charge port pads torn from board
Hi,
I've got myself a switch here that I just purchased as faulty. Was described as charge port being good but opened it up and someones been in here and done a poor attempt at removing the charge port and they've just pulled it off the board, looks like a couple pads missing. Not sure about the inner connections yet but does anyone know if this kinda problem is salvageable?
Believe the charge IC is gone too which is the actual issue and not the charge port which makes this all the more annoying.
I imagine if the inside pads are good I can maybr solder a bit of wire then attach the new charge port pads to the wire and hopefully it all makes a connection. This does take partial power and sent 5v to some capacitors .
I have attached some photos of the damage and hopefully this can be salvageable as it’s an unpatched switch I’d really like to get working for personal use.
Here is a close up of all the visible damage:
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
WOW, well that looks bad. If you can find the schematics for this then you will be able to fix it no problem but first you should see if the device even works. You will have to manually give it power via the correct pins and see if it charges etc and you can buy an old board off eBay and try to track down traces. But when you look at it, you have to ask yourself if its worth the time or maybe can be a challenge you want to take on. As for me, I would try to get another working board off eBay .
这个答案有帮助吗?
得分 0
1条评论:
Yeah I need to take the chargeport off and see the damage on the underside of the pins and then decide from there. As a project it could be fun as i'm new to soldering and pcb repair.
I don't think buying a new board is too viable but I may look into another broken switch as a whole due to it being cost effective and then see from there.
完成的
添加一条评论
添加你的答案
FiddyOnFiddy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 694
