跳转到主内容
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
222 个问题 查看全部
Dead iPad changed charging port and tri chip already
iPad 6th gen had problems charging for the last 6 months. Tried different chargers, cords and cleaned port our originally. Took it to the local ibreakufix shop near me. They replaced the port and then the tri chip and still no power. This is my 5 year old sons ipad and we have had it for approximately 2 years. I have an electrical engineering degree and know how to solder but don’t have the equipment to do micro soldering are this time. My questions is what else would cause this type of issue and/or what to do to being to trouble shoot what’s happening. Also when plugging in to my mac to see if I could update or get in to dfu mode it don’t see my iPad on the Mac USB port. Appreciate any help you all can give or any advice on what I should do. Thank you for taking time to read this and have a great day.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Ok definitely will try what your saying. I appreciate the answers and hopefully can figure this out. It’s my 5 year old sons iPad and really am not trying to buy a new iPad for him at this point. Again thank you for giving me some guidance and hope I can get this figured out. Have a great day :)
完成的
添加一条评论
1个答案
已选择的解决方案
You can check out my answer here (Randomly Shuts Off After Battery Replacement) for a similar problem. In my experience, iPad charging issues follow this pattern:
  1. Check the battery condition with a software tool like 3uTools. If the battery shows signs of wear (less than 70-75% of design capacity), replace the battery.
  2. Check the battery charging with a USB ammeter. If the battery isn’t drawing 1-2A, depending on the charger and charge state, it may be a bad battery or faulty charging circuit. It’s usually the battery ;>).
  3. If/when you open the device, check the screws holding the charge port in place (see step 82 of this guide). The ones highlighted or the ones on top (as seen in the image) can become loose. If they are loose, your charge port flex is almost certainly damaged and will require replacement (micro-soldering required).
  4. If the flex is good and the battery seems fine, then it may be logic board related. This can be the Tristar IC or in some cases the PMIC. The PMIC is a difficult repair and the replacement part is quite expensive.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Randy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 3,263
