跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
iPhone X: screen black but touch works and the glass isn't cracked
After a fall, exactly a 1 meter fall that touched the floor with corner of the phone, the screen turned all black, but the crazy thing is that the screen is not broke and the touch works.
On internet I didn’t found nothing like that, can anyone please help me?
thank you in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hello Kristian
The first thing would be to open the iPhone and make sure everything is in place. Attentive to the necessary tools, they are not usual screwdrivers.
The iPhone X screen is OLED, this makes them more delicate than previous models. OLED screens are easy to break without breaking the glass too. With a good blow the OLED panel could be damaged and stop working while the glass is intact.
For this you must change the screen, there is no other solution.
Good luck!
这个答案有帮助吗?
得分 1
1条评论:
Thank you a lot!
完成的
添加一条评论
最有帮助的答案
either something has dislodged inside the phone which needs connecting back together, unlikely as there’s small panels holding most things down, or parts of the digitizer (the part that's lights up the screen) behind the glass have broken in which case you need a replacement screen as they come together as one.
这个答案有帮助吗?
得分 1
2条评论:
thank you! waiting for other answers!
完成的
@kristian.loshi no problem hope you get it sorted
完成的
添加一条评论
It Could be that one of the flex cables that connects the iphone X screen to the phone is snapped / dislodged, open the phone and check note that you will lost waterproof capabilitys if you open the phone up alternatively you can take it to a repair shop which will diagnose the problem for free after that you can see if you can repair it
这个答案有帮助吗?
得分 1
添加一条评论
how much would it cost to get it replaced?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kristian.loshi 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 71
总计 4,172
