跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Why is it getting so loud?
While it's spinning the cloths there is a loud almost rubbing sound
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. ... If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Keith Boylan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 68
