跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Replacement Keyboard Partially Functioning
I just replaced my keyboard, and everything seems to be back in place and working except for the new keyboard. It seems like that’s usually an issue with not putting the connector back all the way– does the image look correct? Is this keyboard just defective?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
That looks correct, but your replacement may be defective. Do any of the keys work? Did your new keyboard come with a blue piece of plastic covering the pins on the end of the keyboard flex cable? If so, did you remove it? Also if you bend that flex cable alot you may have damaged it.
完成的
添加一条评论
1个答案
Even though it may seem correct, it never hurts to unplug and replug the connector. If the problem persists, try cleaning the inside with a toothbrush. There sometimes might be some gunk.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jillian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 36
