跳转到主内容
于2015年十月26日上市的第四代Surface Pro平板电脑。
210 个问题 查看全部
How can I replace top glass of layer only (LCD and digitizer are fine)
I cracked the topmost glass layer of my Surface Pro 4’s screen. The LCD and digitizer are undamaged and working perfectly. How can I just replace that top glass layer? I found $15 screen protectors made of glass, which I can use to replace the cracked layer. But I'm not sure how to peel the cracked layer off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you are fixing one glass only it is not worth. You need a hot plate and metal wire to remove the front glass, and optical clear adhesive to put a new glass on it.
The "Glass" needs to have the digitizer (touch screen) atached it, a tempered glass or screen protector wont work.
You need tools, screens for practice and hours of work.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sam D 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 630
