跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
series 1 (gen 2) battery and logic board compatible with the original?
I need to purchase a new battery for my original apple watch series 1 gen 1 A1553. I’ve found conflicting statements online as to whether a A1802 battery would be compatible or not. And while I’m replacing it I thought itd be worth while to maybe upgrade the logic board to a A1802 logic board as its more powerful. Would it be compatible? Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
What does the back of the watch tell you it is just 'Apple Watch' or 'Apple Watch - Series 1' or 'Apple Watch - Series 2'?
Without getting a clear idea which model its hard to answer you.
完成的
I literally said i want to put a a1802 board in a a1553 body how more clear can I be about models?
完成的
Many people don't know what they have so I was just trying to make sure.
完成的
添加一条评论
1个答案
最有帮助的答案
Unless you have one of the special edition watches Apple made its not worth the effort. I know someone who transplanted the entire Series 3 insides into a gold case for someone. It was quite a bit of work.
Going between the Series 0 to a Series 1 is not much of an upgrade. I would just replace the battery and call it a day
You’ll need to replace the display and battery with the logic board as the connections are different.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Callum Menzies 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 134
