iPad turns on when plugged in but wont charge
I plugged my ipad into the wall when it is on and wont charge but when I turn it off and plug it in it will power on like it detects the charger but wont charge and also not recognized on my computer
Hello Jayden. When troubleshooting charging issues, I would do the following (in order):
这个答案有帮助吗?
I’m having this issue. What’s cost to replace battery.
过去 24 小时: 7
过去 7 天: 46
过去 30 天: 185
总计 4,270
3条评论
I tried 3 chargers 1 of apple 1 after market with certification and 1 with out only 1 that turns on the ipad is non certified 1 ipad dosent respond to any other cable
As far as I can tell it looks good inside the charging port
I can check with 3utools since the computer isn't recognizing the ipad
I sadly don't have USB ammeter to check
I've also tried a battery swap and it still doesn't make a diffrents
由 jayden gumb 完成的
Most likely the Lightning flex, I change these all the time...
由 Minho 完成的
same thing happends to me i cant find a fix its been like this for 4 hours
由 finn willams 完成的
