跳转到主内容
加入维修社区 - 创建账户
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz 双核 i5 处理器。于 2017 年 6 月发布。
Mid 2017 iMac No power -Replaced Power Supply with no luck - Now what?
I’ve had other iMacs with the no power issue that were resolved by unplugging the power cord and then plugging back in, but when this one continued to have issues, I replaced the power supply…. still no power - no sound, no fan, nothing.
Are there any out there with similar issues that have been resolved that can suggest a next step? I’m thinking Power Button…
Thanks for your input.
Rebecca
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Same thing with me. I replaced everything even the logic board. Nothing. I’m baffled and angry at the same time!
由完成的
添加一条评论
5个答案
已选择的解决方案
The LED’s are telling us we are still having a power issue! Within the logic board is some VRM logic which I’m suspecting has failed.
You’ll need find someone with the needed skills and tools to repair your logic board or you’ll need to replace it.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
What does the onboard diagnostic LED’s telling you?
LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
这个答案有帮助吗?
得分 1
2条评论:
Hi Dan,
Thanks for taking the time to post. I appreciate your help.
Here's what it looks like:
LED 1 0FF
LED 2 Blinks with LED 3
LED 4 ON
Also, the FAN spins then fails.
由完成的
Did you read them from top to bottom? Apple reads them from the bottom up!
Which would mean:
LED1 - On
LED2 & LED3 - Blinking
LED4 - Off
由完成的
添加一条评论
I have no power not a thing is happening not even leds are on
这个答案有帮助吗?
得分 0
2条评论:
@i2cg - in that case you need to start at the AC power outlet checking its voltage, then test cord, the. The AC I put of the power supply. If you see power to the power supply it’s safe to say the power supply has failed.
由完成的
I’ve tested the power cord I’ve changed power supply I’ve tested the board for power and there is voltage but not one thing works. I’ve tested the power button, fine. Should i be looking for a new board
由完成的
添加一条评论
Which would mean:
LED1 - On
LED2 - Off
LED3 - On
LED4 - Off
Can you help me to diagnose issue
Update (04/10/25)
system not getting power on I have open and tested system wen I connect power card LED 1 getting on when I press power baton LED 3 getting on
LED 2 & LED 4 not getting on not getting display also
这个答案有帮助吗?
得分 0
2条评论:
I’ve not seen this configuration of diagnostic LEDs can you give us a bit more info, what is your exact system and what was the state of the system and what did you do.
由完成的
A1418 EMC : 3068
由完成的
添加一条评论
hey! i'm having the same issue here, i'm not sure how or where to get help though. i've removed the display to take a look at the diagnostic LEDs.
LED #1 - ON [when power cord connected]
LED #2 and #3 - blinks
LED #4 - OFF
as LED #2 and #3 blink, a clicking noise occurs and also the fan appears to spin slightly then turn in the opposite direction.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rebecca 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 1,740
