Can the hard disc be replaced
the hard disc has disappeared from the bios boot menu ASUS say that it could need replacing is this possible and how to do it
Hi,
According to the specifications for the laptop, it has 32GB eMMC storage.
Along with the RAM and the CPU, this is hard mounted on the motherboard and cannot be replaced. The motherboard has to be replaced.
This is confirmed by the crucial RAM and SSD checker
Is the HDD still being detected by BIOS and that it is just not showing up in the boot menu?
这个答案有帮助吗?
To change the hard disk you need to open the back of the ASUS laptop and locate the circular disc-like element and replace it.
If the BIOS does not recognize the Hard disk then you may need to check the connection of the hard disc. It may be loose or tampered with by mistake.
这个答案有帮助吗?
can you tell me were the circular disc is located on the board please
Emmc memory, I think their is no way to connect a sata drive in this notebook. But their is a change to change the emmc chip into 512 GB max.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 55
总计 3,303
1条评论
can you post some pics after opening laptop? easy to help you
由 bmx2019 完成的
