Xbox One Coil Whine and Overheating
I recently bought a used Xbox One and it was very cheap due to the noise it makes. When I bought it I thought it was a fan but with further inspection I found the fan to be perfectly fine and not causing any issues. I came to the conclusion that the issue was cool whine to which I couldn’t test because the coil I believe is under the heat sync. I tried to get the heat sync off but even after removing the screws underneath the chassis, I couldn’t seem to remove it. After beginning to set up the Xbox, and start to download games, the Xbox shuts itself off. When I wait about 5/10 minutes for it to boot back up, it tells me it overheated. I’m fine with the coil whine, I don’t really care about the noise, but I can’t play my Xbox if it overheats just downloading things. Anyone know what could be the issue/what I can do to fix it?
Update (01/10/2020)
Don’t everyone respond at once now
