跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Why isn't my phone charging? Part II
Dear community,
I recently had issues with the port replacement: (Why isn't my phone charging?)
Upon re-activating my battery, the phone turns on again. I doesn’t, however, charge.
It is hovering at 1%. The display turns on when I plug in the charger.
I do have another spare port I could put in but am not sure that’s the issue
What could be the underlying issue? Tristar?
Many thanks for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Okay you have ruled out a parts problem. This would be defiantly confirm a faulty component in the charging circuit. Most likely candidate would be Tristar followed by Tigras and or the charging mosfet.
这个答案有帮助吗?
得分 2
6条评论:
Thanks for your insight. That is beyond my capabilities. New phone in winter it is. Thankfully I have a spare iPhone 8.
完成的
The repair on your phone wouldn’t be that expansive. Get a couple of quotes before shelving the phone.
完成的
Will do! Thanks. One last thing: When I use an official Apple charging cable it tells me "this accessory might not be supported". Is that something that also hints at the issues you've mentioned?
完成的
If it’s a certified cable it would indeed.
完成的
It wouldn’t hurt to try a couple of different charging cables. Even if they are aftermarket. I have run into phones that only charge with a specific cable.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Georg Bischof 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 113
