跳转到主内容
A sturdy tablet designed by HP for business and government use.
Why won't the touch screen work unless plugged into power supply
Touch screen won't work unless plugged into power supply
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I’m assuming that the device works on battery normally aside from the touchscreen, right?
完成的
添加一条评论
1个答案
Maybe there is a problem with your internal power supply (battery & wiring).
Check if your battery connector is still properly in place. If yes, you maybe have a damaged or old battery.
It could be that your battery reached the end of it’s life, and it’s not able to deliver enough power to get the screen to work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
patgee69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 180
