跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Backlight upper left corner
Hi,
I recently replaced my screen (backlight, touch, etc)and after few days the upper left corner of backlight stopped working. I powered phone off then on and then backlight worked perfectly for an hour. It happens every time I power off then on my IPhone. Could it be that I didn’t connect properly the flex cable ?
IPhone 6s Plus
Thanks in advance!
Update (01/05/2020)
Thank very much for reply.
I checked if it is not properly connected and it looked connected properly. But, when I turn phone on the flex cable for backlight gets really hot while screen is on. As I suspected, there is a short circuit at very connection and phone cuts current through hot parts. I will order another screen with backlight and test if it is on flex cable or board.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Non properly connection, Bad Back Light from the Screen or Bad back light from the board, always disconnect your battery when you are fixing you phone. Good Luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mare96po 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 73
