跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
Front right USB-C port not working
I can’t get the front right USB-C port of my late 2016 MBP15 with touch bar to work. Connecting peripherals to the port is not working, and also charging via the port is not working. All other ports, including the back right port, are working.
I have been to the Apple Store for analysis and they thought the right USB-C board was faulty. Replacing it would be cheap but would cost >7 days. Therefore I replaced the board myself, to no avail. Nothing changed (on the plus side: I also didn’t break anything).
Things I tried:
  • Flipping the cable
  • Using other USB cables
  • Resetting the SMC
  • Resetting the NVRAM
  • First aid on the disk (from recovery mode)
  • Testing the port while in recovery mode (to make sure it’s not caused by some weird software)
  • Replacing the ports (this part: MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board)
Does anyone have another idea I could try? Thanks!
Replace one of the thunderbolt connector boards from the left or right side of your laptop.图片
产品
$19.99
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Did you find the problem or did you replace the logic board?
完成的
Didn't find the problem, didn't replace the logic board... Think I'll just live with it until I replace the MacBook.
完成的
添加一条评论
1个答案
最有帮助的答案
Sadly, this is starting to sound like a bad component on the logic board around the Thunderbolt 3 controller chip
Double check the connector interfaces on the both the port & logic board make sure nothing is damaged.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your reply! Unfortunately the port board is new so I'm afraid it's indeed the logic board that's broken. Probably not worth it to replace it...
完成的
添加一条评论
添加你的答案
Rutger Bresjer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,974
