跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Spilt Water on Xbox One S
I knocked a glass of water accidentally off of my desk above my Xbox. It wasn't very much but it basically poured right into the fan. I left it to dry for about 8 hours and now it will turn on for a max of 30 second then power off. What should I do? Is there any fix for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try leaving it to dry even longer. I would recommend taking it apart and setting the motherboard at an angle in a dry place. There may still be water on the motherboard under chips.
Otherwise, the power supply might be dead now. If you take it apart and it looks like there’s heavy water damage on the motherboard, then that’s probably not an issue.
这个答案有帮助吗?
得分 1
2条评论:
It really hard to take apart and im not sure i'll be able to put it back together after
完成的
If you don't feel comfortable taking it apart, I would still try leaving it on its side for several days. The only way to truly make sure all the water leaves is by taking it apart unfortunately.
完成的
添加一条评论
添加你的答案
Nate Jakola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 53
