跳转到主内容
加入维修社区 - 创建账户
发布于2013年11月22日的微软第三代Xbox游戏主机。
Console sync button not working
Hi, I have the 1st Gen Xbox one console Halo edition, controllers are both fine, but am having trouble connecting wirelessly as the sync button on the side of the console is making it's click sound, but the xbox logo on the front isn't flashing.
I've tried:
1 - Hard reset with power cycling etc
2 - pulling case apart to check ribbon cable for damage- looks fine
3 - factory reset
4 - unplugging everything except Power & HDMI
I don't believe it's the Bluetooth/wireless card as wifi signal is still fine (I use ethernet normally but checked wifi for this issue) and media remote still works fine
I called Microsoft support, and apparently they no longer offer tech support for the gen 1 xbox one only the one s and one x so they were as useful as tits on a bull
So literally EVERY forum says to try power cycling etc and none of that has helped whatsoever.
Also controller batteries are fine as I run play & charge kits in both and batteries are fine controllers work fine via usb
Literally just the sync button on the console os the issue.
PLEASE HELP FOR THE LOVE OF GOD
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello? Anybody out there?
完成的
添加一条评论
1个答案
最有帮助的答案
To fix this issue it involves a bit of time and some tool.
The side with the sync button you will use a small screw driver and pull the plastic screen off.
Once off the sync button has a piece behind it that will slide out.
Once they are out you will need to start opening the entire case from that side. (Youtube has thousands of how to open videos.)
Be careful not to rip the case open too quickly to avoid damaging the front face ribbon.
When you finally have it open the ribbon attached to the face will need to be checked that it is seated properly being that is what the button signal travels through. If that is connected then you may need to replace the front board to the console or the wireless card that is attached to the top of the metal case.
Best of luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carmelo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 12
总计 701
