跳转到主内容
于 2014 年 10 月 16 日发布,型号为 A1347 和 EMC 2840。
197 个问题 查看全部
Adding Samsung SSD 970 Pro M2 to Mac Mini 2014 with factory HHD
Hi everyone,
I've an old Mac Mini (2014) with the original “Apple HHD“ HD.
I’d like to upgrade it for better performances installing an SSD but since i’m frightened of taking apart the whole machine i’m considering to buy a SAMSUNG SSD 512 GB 970 PRO M. 2
I have two questions though:
1) Is the Samsung SSD 970 Pro M2 PCIe suitable for my mac mini?
2) Is it possible to have both original HHD and the mentioned PCIe installed in the machine or it’s better to replace the old HHD with a brand-new SSD?
Thank you in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Actually I upgraded my mini (i5 2.6Ghz, 8gb RAM) with Samsung 970 pro myself. It was super easy: I bought an adapter for 8$ (with free shipping and tools) and installed it with this nvme added to it. In my mini, it works just perfectly, with speeds just above the 700 MB/s (that’s only because of mini bus limitations). But it’s still 2 times faster than my simple SSD which I have in the place of the old HDD. And now I have two discs in place. So I just love this solution, as it made my mac mini much more usable, at least for a few years ahead.
这个答案有帮助吗?
得分 2
1条评论:
Its not Apple approved ;-}
完成的
添加一条评论
Sadly, Apple uses a different connector than the M.2 blade SSD’s. While some have managed to use an adapter to convert a M.2 SSD to work I really don’t recommend it.
While Apple SSD’s are a bit more expensive I would recommend you go with one of them or either a OWC or Transcend custom SSD’s which better match the Apple SSD’s
Here’s a good source of info and supply of the custom Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs and here’s the guide to follow 2014年末款 Mac Mini 固态硬盘替换
这个答案有帮助吗?
得分 1
添加一条评论
Unlikely without an adapter, best would be to get a good SSD with SATA interface.
You can only have 1 disk (either SSD or HDD) . Read the guide carefully - Step 34
Mac mini 2014 年末机型的硬盘更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Giulio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 1,618
