跳转到主内容
问题已关闭
Can I use it as a display?
The computers logic board is finished, how can I rig it to work only as a display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
5个答案
已选择的解决方案
In short you can't, no easily. You'd need to disassemble and figure out a way to connect the cable that normally goes to the logic board to some sort of adapter. My french is horrible but apparently this thread http://forum.macbidouille.com/index.php?... is all about figuring that out. good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Typically you can't.
这个答案有帮助吗?
得分 0
添加一条评论
No, It can be used only as output for the motherboard. You may want to think about getting another Motherboard.
Tim
这个答案有帮助吗?
得分 0
添加一条评论
You might be better off selling the unit for parts, and taking the money to buy a new 20" monitor :(
You'll probably end up with some leftover cash in the process!
这个答案有帮助吗?
得分 0
添加一条评论
I agree with David, its much simpler and you'd be better off selling it for parts (if iFixit for example!) and then putting that money into a real, newer display.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,599
