Broken display data cable?
Was replacing the Hard Drive. When putting the Retina Display back on I had connected the display data cable and power cable. Powered up fine. Then I was going to put the new adhesive strips on… tilted the display back and it fell out of the bottom, pulling both the display data and power connectors off. When trying to connect them back, the power connector seems to go on fine. The data cable looks like it is in, but not sure. When I turn on the iMac I don’t get any display. What? the data cable pulled out and damaged the on-board connector or the cable?
Have tried to connect them carefully again, same result. What do you think? Sure hop it isn’t the motherboard connector for data. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@macman67 - Could you get some photos of the connectors?
完成的
Post them here for us to see 在已经存在的问题里加入图片 The more detail the better!
完成的
添加一条评论
