跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
return key not working
return key and right shift key not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
What happened? Did you pop off the the keycap?
Most of the time the keycap is broken or not put on correctly.
这个答案有帮助吗?
得分 1
2条评论:
actually both right return and shift keys not working. removed keycap and tried cleaning with contact cleaner and blowing out debris. replaced keycaps, still no go. left shift functioning. also, when using external usb keyboard, right return and shift key work (on external keyboard.) (posted by jmkbaldwin2003, not caseyark) thanks
完成的
Sounds like you didn't put the keycap back on correctly.
Unlike the letter & function key types the larger keys have a bail-wire to stabilize it.
If you don't put the bail into the slot it will block the key from traveling down fully. If you force the pressure you'll damage the parts which can also make repairs harder as you'll likely need replacement keycaps.
KeyCap Finder
How to remove and clean MacBook Pro Retina SHIFT key
完成的
添加一条评论
添加你的答案
jmkbaldwin2003 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 160
