跳转到主内容
A bluetooth and wifi-capable AM/FM radio speaker.
6 个问题 查看全部
Why do I have one side of the stereo less loud than the other?
This happens when using all kind of input (cable jack, bluetooth or network). Stereo sound is bad. One side (left/right) is less audible than the other. It looks like it’s almost muted but I can definitely hear it when muting one side of the stereo sound. I think this might be related to one of the speaker inside but I won’t be against some help. ;-)
Has anybody fixed such kind of issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check the cable by doing the switcheroo. If you did this and the other speaker works, then you can assume that it’s the amplifier and not the speaker. If it’s the amplifier, then it can be either that you are using a secondary device to control the volume, such as a computer or a sound system and it’s settings are wrong. There might be a loose cable inside the AMP, so open it up and check. A fuse or the final FET for that channel might have blown inside of the AMP. Clean up everything inside the AMP and check for components that may look burnt. I hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 78
