跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
iPhone 4s suddenly will not charge and home button unresponsive
I have an old spare iPhone 4s, which has been connected to an iHome speaker since the time I upgraded to a new phone years ago. Being that it was always docked with the iHome, its battery charge should have been at 100% at all times. Yet, a couple weeks ago, I saw where the percentage had dropped from one day to the next. In inspecting this, I also found that the home button has stopped working. I can turn the device back on by swapping in another iPhone 4s’s charged battery. While powered on, I can observe that the home button remains unresponsive and that the iPhone will not react to being connected to a power source. I have swapped out cables in the mix of this, with no improvement (same cables power the other 4s I have just fine). Any easy fixes to explore, or is this unit ready for the recycle pit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like the charger port needs to be replaced.
Though the home button not working as well is not a easy fix as that requires disassembling the whole phone to where the logic board and screen is removed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dpw95 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 36
