跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
My iPhone won't turn on after the battery drained totally
So my iphone 6s won’t charge the battery if it’s fully drained. I tried to change the battery but I got the same results. If I try to charge the battery to another iphone 6s will works. And if the battery have some juice and I put to my iphone that does not wanna charge will work. Also the phone will charge my battery if they have some power. What can be the problem if my phone charge the battery if it’s not 100% drained, but if it’s dead will not turn on to charge it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Theres two things that are common in this situation
  1. The battery protection circuit was triggered and the battery was disconnected from the phone to prevent over discharge. you can verify if this is the case by measuring the battery with a multi meter and seeing a voltage present (usually its 3 or more volts)
  2. The tristar chip has been damaged and will not charge the battery when it gets too low. if the battery displays a voltage on a meter this is the most likely cause and requires micro soldering to repair.
Small note; it is possible for residual power to be drawn from the phone and cause the battery to drop below safe levels even when off, triggering the over discharge protection. This is much harder to test for and requires powering the phone while measuring current draw.
这个答案有帮助吗?
得分 1
2条评论:
and the battery drain much faster even in I left the phone on the sleep mode. Ofc the battery have 82% life.
完成的
I tried to charge the battery on another 6s and worked. So I guess the problem is from motherboard.
完成的
添加一条评论
添加你的答案
richardytb1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 384
