跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
706 个问题 查看全部
Missing resistor near charging port
Hi.
Sorry if this has been asked before or if I'm posting in the wrong section.
Just wanted to ask if anyone can tell me what the 2R2 634f is what the value of the resistor near next to it is. I've circled them in purple.
Pic attached.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
It is a Signal Transformer, some call it a power inductor. The one you need is part # SCIHP0420TB-2R2
这个答案有帮助吗?
得分 2
1条评论:
Thanks Ric. Would you happen to know the value of the resistor next to it?
完成的
添加一条评论
2R2 634F is NS motherboard power inductor Big coil components check this http://egamephone.com/index.php?rt=produ...
这个答案有帮助吗?
得分 2
3条评论:
My switch stopped charging, the battery was draining, and the charging symbol was there, but the battery kept draining. I bought a battery to replace the old one, and when I opened up the switch, this piece was just laying there. What would cause it to break off, and is this the reason my switch isn’t charging?
完成的
@Michael - Same here. Came in not charging or powering on. Powered up with an new battery and would charge if the battery had some juice. Would not charge a dead battery though. I noticed the 2R2 inductor had come undone. Soldered another one from a dead Switch mobo and it works fine now.
完成的
@ACE How did you manage to solder another inductor on with the pads on the underside? Did you have to use hot air?
完成的
添加一条评论
There is no photo attached.
这个答案有帮助吗?
得分 1
1条评论:
Sorry must have missed it. Its uploaded now.
Thanks
完成的
添加一条评论
添加你的答案
email ko 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,867
