跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Inconsistent display issues on early 2013 MBP
Hi all,
I have an early 2013 retina Macbook Pro that's stumped three rounds of apple geniuses.
Symptoms:
No display 75% of the time. I can hear the start chime, but no screen or back light. Occasionally I'll get the login page, but the screen will go black as it loads after login.
I can consistently get to the diagnostics by holding command D at startup. Standard and extended diagnostics run and come back clean.
Every other combination of pressing keys at startup does nothing. The screen never comes on. I did manage to get the apple logo and halfway through the loading bar once while pressing command R, then the screen went black. Three subsequent tries gave me nothing.
The third genius suggested it might be the logic board, but said he was guessing because nothing was showing on the diagnostics. He also said that the fact that the diagnostics come up consistently would indicate a software issue, but he didn't know how to wipe and reinstall without a display.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What does the external monitor show? That would help isolate out which way you need to go.
完成的
Upon testing... I got it to turn on and mirror to an external monitor. Then I restarted, screen didn't come on, no mirroring. Third try, got to the login, no mirror. Logged in, screen cut out halfway through loading the user. Two more tries, startup chime but no screen.
I'm not sure whether mirroring should show on the user login screen or not. If I can get it to start up properly again I'll remove user login and test with an external monitor again.
完成的
Your systems series: MacBookPro10,1 any of these logic boards will work in your system.
完成的
@danj Awesome, thank you!
完成的
添加一条评论
1个答案
已选择的解决方案
You locked the issue down! Yes, your logic board has a problem! The retina series have a more complex display logic than the older unibody systems or even the newer USB-C systems.
Unlike the older unibody 2012 which only had one mini DisplayPort to switch the display output either extending your desktop or mirroring. The retina series have two Thunderbolt ports as well as a HDMI port and to add to this each TB port can support two independent images extending your desktop times two and the HDMI can also mirror!
All this switching and muxing off of the graphics signal feed is a lot of work and we still have two graphics systems! The intergraded Intel CPU graphics engine and the dedicated GPU you have even more complexity!
As you are able to get the display to work sporadically it’s a good sign as you logic board is repairable! Someone with deeper skills and the needed tools/parts can fix your logic board! Apple won’t do that, people like Louis Rossmann in NY could.
The other option is just replacing your logic board MacBook Pro 15" Retina Display Early 2013 Logic Board Replacement. While expensive it is the easier way and depending where you live it might be your only option. Its not overly hard as long as you have the needed tools and a good work area.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kirsten Simmons 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 788
