跳转到主内容
加入维修社区 - 创建账户
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
How to stop the low pressure message!
Hi, I’ve been having a problem with my 2003 Yukon XL where I constantly get a low oil pressure warning. I have checked my oil and it’s been full and clean every time. I have had the sensor replaced recently. I was wondering if anyone knows how to just turn the message off or at least make the annoying beeping stop?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Hi @kt545,
Since you have replaced the oil pressure sender unit get the engine’s oil pump tested by a mechanic.
If there is insufficient oil pressure in an engine it could damage the engine
这个答案有帮助吗?
得分 2
添加一条评论
you would need to disconnect the sensor and program the ecu to ignore both. low oil pressure doesn’t mean dirty and low oil, there’s not enough force pumping it around the car, if the wiring is fine and the sensor there is low pressure, I wouldn’t advise just muting the warning as the engine needs it to lubricate itself and could cause engine failure and an expensive mechanic bill.
这个答案有帮助吗?
得分 0
添加一条评论
Oil pickup o-ring.
Very common
这个答案有帮助吗?
得分 0
添加一条评论
Get a better diagnosis could be a couple things. Ultimately change everything at once unlike me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Katie Mcdonough 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 42
总计 3,250
