5 beeps and 5 beeps.
I searched and found out that the system board has a problem when there 5 beeps and then 5 beeps. How do you fix the system board?
Generally, you cannot fix motherboards due to the soldered components on the motherboard. However, you can replace the motherboard even if it is a laptop. First make sure to note what screws are holding the bottom cover in place and use the required tools. Also, make sure that you are 100% sure that it is actually the motherboard even if the information provided to you is highly reputable.
Generously,
Richard Smith
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 3,537
