跳转到主内容
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
468 个问题 查看全部
Gboard is not available so now I cannot sign in. How can I fix this?
I have a Lenovo Tab 10 TB-X103F and today it said Gboard not available. Now I cannot enter a password to open the screen to do anything. How do I fix this? Reboot nor power off then on fixes this problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
13条评论
I have that too but can't go on Windows
完成的
I am in the same situation - Lenovo tablet, keyboard not working so can't enter my password?
完成的
Same problem. Can't unlock tablet.
完成的
me to not been able to sign in since 14th dec come on google fix this problem
完成的
A soft reset fixed this issue for me! @Per Morten Berg
完成的
显示更多的8条评论
添加一条评论
3个答案
最有帮助的答案
This is a widespread problem today. Fortunately, Google has already released an update. If you can’t log in to your device, and you don’t have auto-update turned on, then go to Play store in Windows and push the update to your device.
Update (12/18/2019)
Go to https://play.google.com/store/apps/detai... on a Windows PC (log in with your Google account info if necessary), click on Install (or Installed), choose the device that is locked out, and click Install. Of course, this will only work if the device is online (WiFi or cellular).
这个答案有帮助吗?
得分 2
8条评论:
I have the same problem, but can't do anything as I cant type my password to open the device
完成的
how do you push the update to your device
完成的
same problem and have pushed update to my device nothing has changed gboard doesnt work still
完成的
I'm the same here. I have three devices so when I go to play store it shows two devices already updated & gives no option to push the update to the locked out device.
It is set up to auto update but very often they don't. You have to go in & push go. But as I can't get passed the password screen I can't do it. The device has been left on 48 hours & still rendered useless.
完成的
How do you push the update to the tablet?
完成的
显示更多的3条评论
添加一条评论
There should be a tiny hole (only big enough for a pin to be inserted) on the side of the device. On my Samsung it's on the top edge, on Lenovo it's on the side. Insert a pin or similar and press. This soft reset allowed my device to install the required update and returned the keyboard to working order. I then immediately removed the password.
这个答案有帮助吗?
得分 0
添加一条评论
Hi I had same problem go on to Lenovo site and it tells you how to reset worked for me I now don't sign in .hope this is helpful x
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
potterandy55 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 42
总计 5,821
