跳转到主内容
加入维修社区 - 创建账户
Xbox One Controller 的维修指南、手册和故障排除帮助。获取自己维修 Xbox One Controller 所需的一切。
My controller isn't turning on and is showing a dim light when I click
I have the Xbox one controller model 1537 I believe. Its not wanting to turn on and shows a dim light. If I plug It in or out a battery pack in and click the middle button it shows a dim light that varies on how bright it wants to be. After that it instantly turns off if you release your finger from the button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Have you tried another battery? If the battery is starting to go flat it will cause the controller to do that.
这个答案有帮助吗?
得分 1
1条评论:
Yes I've tried different batteries, battery packs, and even a cord. I thought it was that at first.
完成的
添加一条评论
Shim the little metal flap on the back of the battery pack. This pushes it out so it makes a solid connection to the row of pins on the controller. I used a flat blade and pried it out a little and shimmed with folded aluminum foil. Has worked for a week without issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 32
总计 6,206
