跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
How do I replace the LCD Screen Rubber Bezel Ring?
I’ve damaged the LCD displays rubber bezel ring.
I have just recently bought a replacement part on eBay. I’ve asked the seller on how to properly replace the piece, but they are not willing to.
Can someone possibly explain how I would do this? I’m not completely tech savvy when it comes to computer internals.
The Retina Display Teardown MacBook Pro Retina Display Teardown gives a pretty good explanation that could be helpful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
The only trick I have is using a little and I do mean little! dish soap (I use the foam type) coating the rubber and then carefully placing the rubber gasket where it sits and then I use a plastic Halberd Spudger to press the gasket in. Being careful not to stretch it as I go. Ideally start the the top middle doing each side so the large tab ends up sitting properly at the bottom.
Hook and Slice your way to repair victory.图片
产品
Halberd Spudger
$2.99
这个答案有帮助吗?
得分 3
4条评论:
Would this be after disassembling the Monitor?
完成的
@mattdido The gasket is the last step after replacing the LCD if that is what you did.
The best way to understand what's done is watch this YouTube vid jumping to Step 3 Replacing a Window Screen 5-Steps See how the gasket is being pressed into the gap. Thats what we are doing here! You can't use a roller as the gasket will get stretched out. Go slowly and make sure the ends land property.
完成的
My Screen is completely fine, it is just the Rubber ring. So I haven't replaced anything.
完成的
@mattdido - Can you post a few pic's on what the damage is 在已经存在的问题里加入图片
完成的
添加一条评论
It is NOT POSSIBLE to disassemble the screen without destroying it for this model.
You need to somehow try to pull the rubber ring out and squeeze the new one in through the gap.
这个答案有帮助吗?
得分 2
添加一条评论
Here is a video of someone replacing the rubber gasket, without doing an entire LCD removal: Change Screen Rubber Mac Book Pro Retina, Frame Ring screen, Rubber - YouTube
So it is doable, but if anyone has successfully completed this process and has any tips or tricks that would be greatly appreciated.
Also does anybody know what tool is being used in the video to push the rubber gasket into place along the edges of the screen?
这个答案有帮助吗?
得分 0
1条评论:
I use a Spudger to push the old gasket out as I pull on it the tech in your vid is using VDM meter probe. I don't recommend metal as you can chip the displays edge. I also use some isopropyl alcohol to clean the edge being careful not to over do it as I don't want it leaking below if I'm just replacing the gasket alone. Often times I tell people to leave it alone as it is a pain to replace and the part is getting hard to find.
Putting in a replacement (or reusing the old one if taken out cleanly) I use some foam dish soap to help lube the gasket and I use a Halberd Spudger using the back of the hook end. One of the hard parts is not stretching it so you have too much at the bottom or if you start at the bottom too much at the top!
Its a long of delicate time consuming work! Unless you have the gasket and you had replaced the panel alone I wouldn't recommend doing it. As long as you have a good portion of gasket still present I would leave it alone
完成的
添加一条评论
添加你的答案
Matthew DiDomenico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 77
总计 12,033
