跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
Troubleshooting new Screen and waterlogging
Hi all,
I'm trying to troubleshoot what could be wrong so I'll spell it out step by step.
My partner has a series 3 42mm GPS only watch. She cracked the screen, I replaced it with a part bought in China. The new seal was a fraction too small over one corner and I told her not to get it wet.
Later, she jumped in a pool without realising and the watch stopped working straight away.
I lifted the screen up and there was water inside. I disconnected the battery, sprayed isopropyl alcohol inside, later hit it with a hair dryer for a while and left it with the screen open for 2 days. After that I rebooted it and it came back to life, unbelievable!
It stayed on the charger, working properly for 2 days until yesterday when I disconnected the screen to put a new seal on. I connected the screen back on and nothing, no sign of life. At one point it vibrated when I held down the button for a few seconds but it hasn't responded to any button pressing or rebooting since then. I've tried recharging, nothing.
I'm at a loss what to try next. Any ideas on what it could be?
I was pretty careful disconnecting and reconnecting the screen, could it be a broken cable maybe? Or is it possible the battery just upped and died due to the water coincidentally when I was doing the work?
Any pointers would be most appreciated.
Cheers, Ben
Update (12/12/2019)
So an update - After 3 days of nothing, just sitting on the charger unresponsive, we get home from an outing and the watch is beeping away, I guess like the find my watch function?
Except we haven't touched the watch app at all on the iPhone it's paired to. Still no screen though. I pressed the button and the beep stopped. I tried a hard reset and after a couple of minutes the beeping started again.
Is this indicative of anything, other than the watch is royally screwed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Whats your skill level is it limited to changing screens or can you use a multi meter?
完成的
Skill level is pretty rudimentary - just what I've learned through YouTube. I haven't used a multi meter before but always willing to learn something new.
完成的
添加一条评论
1个答案
最有帮助的答案
Thanks for not using rice LOL. If it worked before you disconnected the screen to put new seal in then it must be the screen or cable. If you get another screen maybe you will have success. Worth a try.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ben Noble 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 95
