跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
How to Upgrade Memory Ram?
How to Upgrade Memory Ram ????
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You can’t! The RAM is soldered to the logic board. But! You could replace the logic board with one which has more RAM. But there is a limit here! 16 GB is the largest you can go with MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.2 GHz 16 GB RAM Logic Board and MacBook Pro 15‘’Retina显示器2015年中期主板交换
Replace a 2.2 GHz Core i7 logic board (motherboard) compatible with the Mid 2015 Integrated Graphics model MacBook Pro 15" Retina laptop. Fix processing issues like unexpected shutdowns, reboots, or water damage. Included Ports: 2 Thunderbolt (Mini Display Port), USB 3.0. Includes 16 GB RAM.图片
产品
$168.99
这个答案有帮助吗?
得分 1
添加一条评论
Ok there is two ways 1 is to do as suggested and buy a board with 16gb already installed that is much easier the long answer is you can although you would have to buy a solider reworks station and out source 4 ram chips for your particular model unsolder the existing ones with flux reball the new ones solder them on in the correct direction seal it up and pray that it works if somebody that is unskilled in soldering attempts there is no guarantee that it will work really it is a gamble so it might be worth the 8gb that is already in your system to just stay in there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
AMILKAR MARCH LEBROC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 4,556
