Are parts of iMac 5k 2019 interchangeable with the 2017 version?
Can I buy the metal housing of a 2017 iMac 5k and use it for a 2019 5k iMac?
What about LCD’s? If my 2019 screen is damaged, can I buy a 2017 screen, with the same model name?
I don’t know of anyone going to this extreme! Apple is good about its parts numbering so parts which carry forward are the same P/N. If there is any differences it gets a new number.
So… looking just at it this way we can see 2019 iMac 27" Retina 5K Rear Housing Unit, Apple P/N 923-03064 Vs 2017 iMac 27" Retina 5K Rear Housing Unit, Apple P/N 923-01666 are different! Are you sure you need a new case? You still need to transfer parts over and there are some sundries that are needed.
As far as the display: 2017 iMac 27" Retina 5K LCD Panel & Front Glass Assembly, Apple P/N 661-07323 Vs 2019 iMac 27" Retina 5K LCD Panel & Front Glass Assembly, Apple P/N 661-12558 again, the part numbers are different!
这个答案有帮助吗?
i found this link re the question : https://witcomputers.com/product/imac-27...
这个答案有帮助吗?
Apple upgraded the display assembly part with a brighter panel. Both the LCD and the LED backlights where upgraded. Otherwise the part is electrically and mechanically the same.
What will happen if you connect a 2020 5k lcd on a 2017? Connectors are the same camera can be taken out so the screen will fit, camera connector is the same.
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 1,884
