跳转到主内容
The RIDGID R2740 is a heavy-duty corded belt sander. The intended use of this device is meant for, but not limited to woodshops, at home and construction sites.
2 个问题 查看全部
similar Craftsman 3x21 Belt Sander 315.117260 disassemble for repair
Upon disassembling the sander, I found that the left armature bearing failed, heated, and melted the plastic holding it in place. I can’t get the gear off of the armature in order to take the damaged parts off. I think it’s reverse threaded, but no way can I get it to budge. Help I would think a repair should be possible. Or, have Craftsman tools gotten so bad that this cannot be repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you tried heating the part?
这个答案有帮助吗?
得分 0
1条评论:
Hi Kevin, No, I pretty much gave up and set aside the tool. I recently found the box that I put it in - maybe I’ll give it another go. BTW, would you be interested in buying this for parts? Chris
完成的
添加一条评论
ereplacementparts shows parts available
https://www.ereplacementparts.com/ridgid...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Longwill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 299
