跳转到主内容
Keyboarding is not working and external USB keyboard won't work
I have an Asus laptop model X540S, the keybaord stopped working and I am locked out because my laptop is password protected. I attached an external USB keyboard and that will not work. Any thoughts ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you attach the external keyboard before turning on the laptop?
完成的
添加一条评论
2个答案
最有帮助的答案
If you already tried all the laptop’s USB ports for the external keyboard, you may have to remove the computer’s keyboard and install a different one.
这个答案有帮助吗?
得分 1
添加一条评论
Try starting it up in “Safe mode” and see if it will load then. If yes, then there is something on the laptop(virus, malware, etc.)
1-Then try to restore it to an earlier situation using restore point option.
2- Or go to the Driver & Tools on the related ASUS web page :
www.asus.com-Laptops-X540SA-HelpDesk_Download
download all the related drivers again and save them in a stick memory. Try to install them in safe mode if it is possible.
But before that try to use the attached keyboard and boot in safe mode (following text).
I hope it helps:)
Boot in safe mode(Wondows 10)
A-Turn off the device. Attached the external USB keyboard again.
B-Click Windows-button → On/Off.
  1. Hold down the Shift key and click Restart.
  2. Click the option Troubleshoot and then Advanced options.
Afterwards go to “Advanced options” and click Start-up Settings.
Under “Start-up Settings” click Restart.
Several boot option are displayed.
Select an option by pressing one of the numbers or function keys F4, F5 or F6
Enable Safe Mode
In this mode, the operating system is started with the bare minimum of installed drivers and only the main Windows functions are used.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CorgiGirl User 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 106
