iMac won't turn on
It does not work, when opening the iMac from the inside, I found that when I press the power button only the fans turn on and then turn off
Update (12/08/2019)
Only LED #1, what’s the problem now please
In the bottom left corner of the logic board is a strip of tape covering over the onboard diagnostic LED’s. Carefully remove it so you can see them. Tell us what you see.
Here's a breakdown of the onboard diagnostic LED's:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 115
1条评论
Did you try a new PSU? As stated under LED 2.
由 DanJ 完成的
