跳转到主内容
This receiver is Bluetooth Ready, has 110 Watts x 5 Direct Energy Amplification and is iPad / iPhone Certified with supplied cable
26 个问题 查看全部
Volume knob turns unit on and off
My unit isn’t exactly shown in post. It is a Pioneer “elite” VSX-xxxx unit. Fairly new.
If i turn the volume knob the unit turns off, then if i turn it back to a certain position unit comes back on. Using a remote has no effect on it so everything is ok so far…
It seems like the unit is shorting out when turning the knob… Does anybody know what part could be faulty? Do I need to replace? or possibly clean the potentiometer?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unless your receiver is pretty old, the volume knob probably doesn’t have a potentiometer. Instead, it has a digital rotary encoder. Theoretically this could be cleaned too but that’s not likely to help. If the receiver functions just fine using the remote to adjust the volume, then there might be something going on with the receiver’s software. You can try resetting the receiver using the process described in the owner’s manual (typically something like unplugging it and letting it sit for a few minutes, but some receivers have a more specific reset process). If your receiver has a motorized volume knob that turns when you adjust the volume by remote, then there probably is a potentiometer that could be serviced. Unplug the receiver, use an electronics cleaner such as Deoxit, let dry thoroughly, then follow up with a small shot of electronics lubricant. Be sure to only use cleaners and lubricants that are specifically designed for electronics and make sure the equipment is fully dry before plugging back in. You can try this process if your receiver has a rotary encoder instead of a potentiometer, but that might not solve the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sho VanArsdale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 153
