跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Hardware differences between the Switch v1 and v2?
what hardware differences are there between the v1 Switch and the newly refreshed v2 switch? Are they still using the same motherboards and are the displays compatible with each other? I am looking at repairing some broken Switches and need to know if parts can be swapped between revisions or if this is not possible. The ore detail the better and any help is greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The boards are not the same since the v2 has a newer SoC revision. Also the battery is a bit larger in capacity. Regarding the screen, I don’t think they have any reason to change the design.
这个答案有帮助吗?
得分 1
1条评论:
Can a V2 mother board install as a replacement for a v1 motherboard. In other words, are all the other parts compatible?
完成的
添加一条评论
The battery is exactly the same. The longer play time comes from shrunk chips…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lolderp144 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,474
